Neye ihtiyacın var
First flip the mouse over and unscrew the single screw at the bottom.
I will not be showing how to remove the light because I do not have the correct tool to do so.
A mouse works by having the red light reflect back and then it detects how much light was shown or blocked off to figure out which way the mouse has moved.
A mouse will sometimes use potentiometers, or rodary encoders to then covert the motion of the wheel spinning, to digital codes. That info will then transfer up through the mouse, through the USB cable, then into the computer. The USB cable also provides the power for the mouse by transferring energy from the computer.
Now open apart the two pieces carefully so you don’t end up having everything on the inside explode all over you once it’s opened.
Ditto to the person who said that the picture was a huge help with that little spring. I could not figure that out! I cleaned enough moisturizer out of one tiny section that I got it working correctly again! Thank you!!
Remove the centerpiece with the wheel and tilt it to the right so the spring can slip off.
Then remove the left wire by pulling it out of the socket it’s put in.
The spring here is what let’s you press down on the wheel without letting it get stuck there. It basically bounces it back up. And the wire on the left is under tension to hit the inner side of the wheel, giving the the scroll wheel some ratcheting.
This part is a tiny bit difficult. To remove the USB cable you have to use your fingers to pull up on the tab. It takes awhile because you have to be careful to not accidentally bend the plastic casing it’s in. Luckily once’s its out it’s extremely easy to put in.
11Kılavuz Yorumları
how do i put it back together, though?
okay, but how does it go back together?
The way you put together (I assume you’re interested in the wheel) is as follows, looking at the mouse from the above, buttons at the top.
- The spring that’s spooled up goes to the right side of the wheel, the spring that’s a bit more curvy goes to the left side of the wheel.
- Try to assemble the plastic piece with the wheel - they should look as Step3 / Pic1.
- Put it back into the housing, to give you a guidance how it should look like.
- Take it out and disassemble.
- Add the left spring with its rectangle corner, one end of it to the wheel holder, for the other end there is a small hole on the left part of the plastic piece.
- Add the wheel. Try to roll it, you should hear the usual clicking voice.
- Put the right spring to the right side of the wheel, to the rod.
- Put the assembly back into the housing. Try to click the wheel - the right spring should bounce it back.
Hope this helps.
Thank you thank you! I had opened mine up to do a thorough cleaning and SPROIINNNNGGGG… then I had no clue how to get it all back inside. Your 2nd photo on Step 2 gave me exactly what I needed to be able to reassemble!! So thank you!
If anyone’s wondering, the old-fashioned mouse (with the rubber ball underneath) has the exact same scroll wheel assembly as the kind with the ‘light’, like in your photo.
Could you please tell where can I find the replacement cable for B100 mouse or the white connector ? I have damaged the cable and I need to replace it. I have another cable but do not have the connector.
Thank you so much – my mouse was behaving erratically, so I carefully took it apart, found it full of fluff and gunk and in the process of cleaning it out, SPROIINNNNGGGG – couldn’t have figured it out for myself, so your guidance saved the day. Thank you.
Who invents these things?
Superb! I thought I was going to have to throw mine away
I want to say thank you for this, I couldn't figure out where the spring went on the right side of the wheel that one. It's sprung off but that was as soon as I opened up the top of the mouse I didn't know where it went when i put it back together. Oddly enough I didn't need the spring as much as I thought because the internal wheel spring the one that makes it click and stop actually provides just enough to push it back up, I know it sounds weird but it is true but I know I needed that spring to go back in somehow somewhere so thank you for having this online. After replacing the switches which is what I did worked flawlessly in replacing them but that darn spring. Heh.
4 to 5 years I've had this mouse never had a problem, except for the switches this is a darn good mouse overall.
Si hubiera un vídeo sería más fácil, así me ha costado mucho , gracias por las fotos
But but but but.. THANK YOU!!!! Finally I could fix my mouse as well thanks ONLY to this tutorial! Incredible, I had to think a bit more about the second part (re-assemble everything again) but at the end, after a bit of thinking over it and with calm, I could fix everything back again.
Really thank you, God bless you for the help, brother! xxx from ITALY! Valentina
The Sighing Dutchman - Yanıt
