Ana içeriğe geç
Outline what you are going to teach someone how to do.
Bu teardown bir tamir kılavuzu değildir. Set-Top Box cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. M8s OTT TV BOX  Teardown, M8s OTT TV BOX  Teardown: adım 1, 2 resimden 1. M8s OTT TV BOX  Teardown, M8s OTT TV BOX  Teardown: adım 1, 2 resimden 2.
    • Remove 4 circle pads to access the 4 screws. Using a Philips head screwdriver, remove all 4.
  2. M8s OTT TV BOX  Teardown, Remove the bottom: adım 2, 3 resimden 1. M8s OTT TV BOX  Teardown, Remove the bottom: adım 2, 3 resimden 2. M8s OTT TV BOX  Teardown, Remove the bottom: adım 2, 3 resimden 3.
    • Remove the 4 circular pads, then using a Phillips screwdriver. Remove the 4 screws.
    • Using the metal spudger in the slits parallel to the Seal you will be able to separate the two piece's.
    • The piece should come off easily.
  3. M8s OTT TV BOX  Teardown: adım 3, 3 resimden 1. M8s OTT TV BOX  Teardown: adım 3, 3 resimden 2. M8s OTT TV BOX  Teardown: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • With a firm grip at the base of the cable pull up and away from board.
    • Locate the 4 screws, then using the Phillips screwdriver remove them.
    • Before the board can be removed, be sure to use your tweezers to untape the antenna from the housing.
    • The board should come out with ease.
  4. M8s OTT TV BOX  Teardown, Remove the LED board: adım 4, 1 resimden 1.
    • Using your Phillips head screwdriver remove the 2 screws that hold the unit to the housing
  5. M8s OTT TV BOX  Teardown, Remove the steel heat plate: adım 5, 2 resimden 1. M8s OTT TV BOX  Teardown, Remove the steel heat plate: adım 5, 2 resimden 2.
    • With your Phillips head screwdriver, remove the 3 screws that hold it in place.
    • The device has been effectively disassembled.
    • Next I will guide you through a Detailed inspection of the main circuit board.
Austin Pollard
1.495 İtibar
3 adet Kılavuz yazıldı
Ekip
Reno Phone Repair Reno Phone Repair üyesi
Business
1 Üye
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 45
Son 30 gün: 55
Her zaman: 2,430
