Giriş
This is a good teardown when you will finally see what is under the black panel on the rear. It can also guide you to change the battery, if needed :)
Have a nice reading.
After removing the back cover, use a torx T5 to remove all screws at the back
Use an opening tool or plastic spuged to remove the outer frame.
22 Comments
The procedure is very simple, but i realise that take off all the screws is a little bit difficult. As well, remove the motherboard that is attached to the plate behind the screen.
Question. How difficult is it to replace the glass?
I'm just about to have a go at it now!
I'll let you know
Just replaced the broken screen on my XT1039. Be aware XT1032,XT1033, XT1039 - the screen components are all the same. I bought the screen/frame/digitizer as one unit for the XT1032. It was relatively straight-forward with a bit of care and attention in certain areas. After you've taken the 14 screws out the rest of the phone is basically glued together with sticky-strips. I followed the advice on a You-tube video and used a hair dryer to heat up the ribbon cables and to loosen the earpiece. Phone now fully functional - hooray! Thanks to all on this forum!
Can we further dismantle individual elements on motehrboard? Like I want to replace the memory.
