Giriş
Neye ihtiyacın var
Videoya Genel Bakış
- The battery is fairly easy to swap out once you remove the back cover.
- The rear panel is secured by tri-point screws.
- The headphone jack and charging connector are soldered to the motherboard.
- The upper display is glued in place and requires prying that can potentially break the display.
Son Düşünceler
Onarılabilirlik Puanı
4
Onarılabilirlik 10 üzerinden 4
(10 en kolay onarılabileni)
19Kılavuz Yorumları
yet another yootoob tear-down...why? whats wrong with the others - some peeps cant get to yootoob during the day!
P Stephenson - Yanıt
Any idea how I can get my hands on a replacement back frame. I found a crack in the bottom right corner.
Nathaniel Canning - Yanıt
Why can’t i find a direct 2ds close upper screen replacement? Is it the same screen as the 3Ds Xl?
John - Yanıt
It’s not the same, the 2DS screen is in 2D and the 3DS has a 3D screen
Liam Judge -
Warning!
In the teardown video they show how to remove the ribbon cable, but beware! Two of these cable dont have the regular easy fit where you lift the flick to get it open and remove the cable. (Yes, they do this in the video and brake it.) Once they’re open” they wont close again.
The cable right above the cart slot is ond and the closes cabel to the joystick is the other. (The two with the back connectors)
BEWARE!
I have not tested this yet but it seems as it is a tight push fit to these ribbon cables.
If there is so, please let other people know so they dont do the same mistake as i by opening it and cannot close it again.
In worst case your New 2DS XL turn on!
Daniel - Yanıt
