Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. OnePlus 7 Pro cihazınızı onarmak için, servis kılavuzumuzu kullanın.
    Son Düşünceler
    • The battery can be removed first, once you open the phone. It’s only lightly adhered and comes with a pull tab for easy removal.
    • Many components are modular and can be individually replaced.
    • Display replacements, which are the most common repairs, are not prioritized in the design. (You have to completely disassemble the phone to swap out your screen.)
    • While the Front Facing Camera’s new pop up ability is really cool, the added mechanical element makes it more likely to wear out and more complicated to replace.
    • The primary access point for all repairs, the rear panel, is firmly glued in place.
    Onarılabilirlik Puanı
    4
    Onarılabilirlik 10 üzerinden 4
    (10 en kolay onarılabileni)
6 Yorum
What is the best way to get rid of slider?
Can it be cut from outside w/o unglue back cover?
Bob Monkas - Yanıt
Slider? Do you mean the pop up camera? If so, removing it is major surgery, cannot be done from the outside.
Forge -
Can I replace the 256 memory module? Need to salvage some things on it.
vishal.shah.tx - Yanıt
OnePlus 7 pro 8/256
Anita Jajoriya -
do i need to remove the pop up camera if i want to change the screen?
romain.collet - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 51
Son 30 gün: 273
Her zaman: 70,369
