Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Samsung GT-E1200I cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Samsung GT-E1200I Teardown, Remove the back cover and the battery: adım 1, 2 resimden 1. Samsung GT-E1200I Teardown, Remove the back cover and the battery: adım 1, 2 resimden 2.
    • I have used the Jimmy for this job.
    • Be careful when you pry with your Jimmy. It can hurt you if you use it the wrong way.
    • All the tools featured in this guide are available in the Pro Tech Toolkit.
  2. Samsung GT-E1200I Teardown, Remove the inside panel: adım 2, 3 resimden 1. Samsung GT-E1200I Teardown, Remove the inside panel: adım 2, 3 resimden 2. Samsung GT-E1200I Teardown, Remove the inside panel: adım 2, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the three screws.
    • Pry and remove the panel with an opening pick.
  3. Samsung GT-E1200I Teardown, Speaker: adım 3, 1 resimden 1.
    • Remove the speaker with a spudger.
    • Do not force it off. If you do, you could break your speaker.
  4. Samsung GT-E1200I Teardown, Vibracall: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the vibracall engine with the tweezers
  5. Samsung GT-E1200I Teardown, The mainboard: adım 5, 3 resimden 1. Samsung GT-E1200I Teardown, The mainboard: adım 5, 3 resimden 2. Samsung GT-E1200I Teardown, The mainboard: adım 5, 3 resimden 3.
    • Remove the mainboard with the spudger:
    • Move on side here for detach the screen
    • Pull up here for remove the mainboard
    • The screen is soldered to the mainboard. If you are replacing your screen, you need a desoldering iron.
  6. Samsung GT-E1200I Teardown, The keyboard: adım 6, 1 resimden 1.
    • Separate the rubber side of the keyboard from the rest of structure
  7. Samsung GT-E1200I Teardown, That's all: adım 7, 1 resimden 1.
    • It's all done!
Stefano De Rossi
468 İtibar
2 adet Kılavuz yazıldı
2Kılavuz Yorumları
I have a samsung GT-E1200I and the port for the charger has died on me. I’ve tried it on several chargers and
there is no signal. I plugged it in and it just went dead. The problem is, I need to get the numbers I had. Is there any way of doing this?
edward - Yanıt
The numbers are maybe stored in the SIM? Have you tried to move the SIM on another phone?
Stefano De Rossi -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 724
