Ana içeriğe geç
This will be an complete teardown of the camera. The camera, that was torn down had problems with the moving lens.
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Sony Cyber-shot DSC-HX400V cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Sony Cyber-shot DSC-HX400V Teardown, Take your Camera: adım 1, 1 resimden 1.
    • 20.4 MP CMOS Sensor
    • 50x Optical Zoom
    • GPS, NFC and WiFi
  2. Sony Cyber-shot DSC-HX400V Teardown, Case: adım 2, 3 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Case: adım 2, 3 resimden 2. Sony Cyber-shot DSC-HX400V Teardown, Case: adım 2, 3 resimden 3.
    • Remove the eight screws.
    Size 0 IFIXIT screwdriver bit.
    Bummers - Yanıt
    These screws are black, fine thread 4.3mm long.
    Bummers -
  3. Sony Cyber-shot DSC-HX400V Teardown, Take the Case apart: adım 3, 2 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Take the Case apart: adım 3, 2 resimden 2.
    • Begin with the bottom and pull the case apart.
    • Be careful with the ribbon cable of the display.
  4. Sony Cyber-shot DSC-HX400V Teardown, Seperate the Case: adım 4, 3 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Seperate the Case: adım 4, 3 resimden 2. Sony Cyber-shot DSC-HX400V Teardown, Seperate the Case: adım 4, 3 resimden 3.
    • Free up the connector under the black tape.
    • Disconnect the ribbon cable.
    • You need to pull up the brown edge of the connector to open it. (Here shown with another connector of the next step.)
    • This cable is used to connect the display as well as the button on the rear site to the mainboard.
  5. Sony Cyber-shot DSC-HX400V Teardown, Disconnect Motherboard: adım 5, 2 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Disconnect Motherboard: adım 5, 2 resimden 2.
    • Disconnect all seven remaining ribbon cables.
    • Disconnect these with the technique from the last step.
    • Simply pull these out of the connector. There are small edge at the cable to easily pull them out.
  6. Sony Cyber-shot DSC-HX400V Teardown, Speaker: adım 6, 2 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Speaker: adım 6, 2 resimden 2.
    • Unscrew both screws
    • Take out the bracket. You can then remove the bracket from the speaker.
    • Be careful with the cable between the speaker and the motherboard.
    • The speaker bracket is also the mount for the camera strap.
    Both screws, “self tapper” style, black, 5.3mm long.
    Bummers - Yanıt
  7. Sony Cyber-shot DSC-HX400V Teardown, HDMI and MicroUSB Connectors: adım 7, 3 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, HDMI and MicroUSB Connectors: adım 7, 3 resimden 2. Sony Cyber-shot DSC-HX400V Teardown, HDMI and MicroUSB Connectors: adım 7, 3 resimden 3.
    • Unscrew all three screw that are holding the bracket down.
    • Lift up the bracket and then the connectors.
    These three screws are silver color (stainless steel?)
    Bummers - Yanıt
    All 3 screws 3.8mm long.
    Bummers - Yanıt
  8. Sony Cyber-shot DSC-HX400V Teardown, Mainboard: adım 8, 2 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Mainboard: adım 8, 2 resimden 2.
    • Unscrew the three screws.
    • Be careful with the small cable to the NFC (and WiFi?) antenna which is glued to the battery case.
    • Turn the mainboard around and disconnect the last ribbon cable.
    3 x screws, silver, 3.8mm long.
    Bummers - Yanıt
  9. Sony Cyber-shot DSC-HX400V Teardown, Viewfinder and Flash-Socket: adım 9, 1 resimden 1.
    • Unscrew the four screws.
    • Note that the two bottom screws are shorter than the others.
    • The viewfinder sits inside the bracket of the flash socket. On right beside the electronic viewfinder (aka display with lens), there is the proximity sensor which is used to switch between the display and the viewfinder.
    The 2x top longer screws are 5.3mm long, black, “self-tapper” style thread.
    The 2x bottom screws are only 2.4mm long, also black but fine thread.
    Bummers - Yanıt
  10. Sony Cyber-shot DSC-HX400V Teardown, Viewfinder Insides: adım 10, 3 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Viewfinder Insides: adım 10, 3 resimden 2. Sony Cyber-shot DSC-HX400V Teardown, Viewfinder Insides: adım 10, 3 resimden 3.
    • Frontglass holder
    • Frontglass, you may want to clean it, if you have disassembled it
    • Lens with spring. This is used to give you a sharp view into the viewfinder. The small nib is pushed in different positions by the small dial on the case to adjust the focus for your eyes
    • Monitor, a very small monitor. Looks much like the image sensor.
    • Proximity sensor for detecting your eye and therefore switching to the viewfinder.
    • PCB with 2 unidentified ICs (659L and 3232 615)
    • Backcover
  11. Sony Cyber-shot DSC-HX400V Teardown, Baseplate: adım 11, 3 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Baseplate: adım 11, 3 resimden 2. Sony Cyber-shot DSC-HX400V Teardown, Baseplate: adım 11, 3 resimden 3.
    • Disconnect the ribbon cable to the GPS module at the top.
    • Unscrew the last two screws of the baseplate. Then pull the baseplate to back.
    • Be careful with the GPS module when pulling out the baseplate.
    These 2 screws are 5.3mm long, black, with “self-tapper” style threads.
    Bummers - Yanıt
  12. Sony Cyber-shot DSC-HX400V Teardown, Battery Case: adım 12, 2 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Battery Case: adım 12, 2 resimden 2.
    • Unscrew the battery case and pull it out.
    • Make sure you have DISCHARGED the flash capacitor before. Now you could touch it and may get a electrical shock. It is rated for 315 V and 134µF.
    • Be careful again with the cable between the mainboard and the antenna.
    • Disconnect the ribbon cable, unscrew the flash PCB from the battery case and pull them apart. Finally, the mainboard (and therefore the antenna and battery) is separated from the rest.
    These two screws 5.3mm long, “self-tapper” style.
    Bummers - Yanıt
    The one flash PCB screw is 6.3mm long, silver, “self-tapper” style thread.
    Bummers - Yanıt
  13. Sony Cyber-shot DSC-HX400V Teardown, Button Panel: adım 13, 3 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Button Panel: adım 13, 3 resimden 2. Sony Cyber-shot DSC-HX400V Teardown, Button Panel: adım 13, 3 resimden 3.
    • To remove the button panel, you have to unscrew these two screws.
    • When reinserting, make sure that the nib for the zoom is in the middle position. Otherwise it will zoom the whole time.
  14. Sony Cyber-shot DSC-HX400V Teardown, Remove Optics: adım 14, 1 resimden 1.
    • Unscrew these 4 screws to seperate the optics part from the rest of the case
    • Unscrew these to loosen the motor from the sensor backplate
  15. Sony Cyber-shot DSC-HX400V Teardown, Sensorbackplate: adım 15, 3 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Sensorbackplate: adım 15, 3 resimden 2. Sony Cyber-shot DSC-HX400V Teardown, Sensorbackplate: adım 15, 3 resimden 3.
    • Unscrew these 6 screws, after you have taken the optics out of the case. Note that the three motor screws where in place during the photo, but should be removed first
    • To be able to separate the Sensorbackplate from the rest, you have to unsolder the conenctor
    • Also disconnect this connector, as well as the connector on the opposite site
    • Finally you have the sensor with (maybe?) the auto focus lens.
    • If you have dust on your images, it is not necessarily on the sensor. It is rather unlikely because it is enclosed from the auto focus lens. Maybe you should search on other part of the optics first
  16. Sony Cyber-shot DSC-HX400V Teardown, Optics: adım 16, 1 resimden 1.
    • The rest of the optics contains 3 tubes as well as 3 moving lenses
    • Unscrew the 4 screw to loosen the sprocket
    • Before you can remove it, you have to floss the 2 ribbon cables through the outer case. It is not easy, you have to rotate them, but it is manageable
  17. Sony Cyber-shot DSC-HX400V Teardown, Tubes: adım 17, 3 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Tubes: adım 17, 3 resimden 2. Sony Cyber-shot DSC-HX400V Teardown, Tubes: adım 17, 3 resimden 3.
    • The outer case has a gear mount and grooves for the inner tube.
    • This tube has the front lens integrated and is visible to the outside when the camera is turned on and zooming.
    • The inner tube moves all 4 lenses.
    • This groove moves the tube with the front lens.
    • The three inner grooves moves the image stabilisation, the shutter and an additional lens.
    • This nip interacts with the grooves in the outer tube.
    • This is the dust and dirt that was stopping the objective from moving out. It isn't much. So, be careful and keep yours clean. I was not able to completely remove it in my camera, but it is working now with some help.
  18. Sony Cyber-shot DSC-HX400V Teardown, Lens Groups: adım 18, 3 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Lens Groups: adım 18, 3 resimden 2. Sony Cyber-shot DSC-HX400V Teardown, Lens Groups: adım 18, 3 resimden 3.
    • Unscrew all 5 screws to remove the rod holder. Then you can separate all three optics groups.
    • This is a moving lens with no other purpose
    • This is the shutter and aperture module. It also integrates some lenses.
    • This is the image stabilisator, which contains two coils and magnets.
  19. Sony Cyber-shot DSC-HX400V Teardown, Shutter and Aperture: adım 19, 3 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Shutter and Aperture: adım 19, 3 resimden 2. Sony Cyber-shot DSC-HX400V Teardown, Shutter and Aperture: adım 19, 3 resimden 3.
    • The shutter and aperture is combined into one assembly.
    • The shutter seems to be actuated by a magnet.
    • I was able to open and close the shutter with a magnet.
  20. Sony Cyber-shot DSC-HX400V Teardown, Image Stabilizer: adım 20, 3 resimden 1. Sony Cyber-shot DSC-HX400V Teardown, Image Stabilizer: adım 20, 3 resimden 2. Sony Cyber-shot DSC-HX400V Teardown, Image Stabilizer: adım 20, 3 resimden 3.
    • You can see the two magnets, that are used to move the lens
  21. Sony Cyber-shot DSC-HX400V Teardown, Overview: adım 21, 1 resimden 1.
    • These are all disassembled part. Not everything is removed from the case and disassembled entirely
Quanten
1.016 İtibar
5 adet Kılavuz yazıldı
27 Yorum
Thanks a lot for the instruction. I managed to clean my camera from Sahara-sand. It saved me from a €300 repair bill
han.evers - Yanıt
Helo ..what kind of bit and size do I have to buy?
Is it ph000?
I Hope
Datyur Natyur - Yanıt
I’m sorry, but I don’t know, but I would think, that ph000 is too small
Quanten -
I found an IFIXIT size 0 Phillips bit fitted the screws
Bummers -
there is a light ‘'sounds” from the lens part every time I turn it ON it is sounds like broken plastic …. is this common ?
Don - Yanıt
Thank you for this! I found it very useful in helping me try to repair (unsuccessfully) the dreaded E62:10 issue. I have two requests:
1) Could you expand this to illustrate the insides of the image stabilizer?
2) Could you identify the two small electronic components soldered to the ends of the image stabilizer cable (the parts that fit face down unto the magnets)?
I successfully replaced my image stabilizer cable using your tear down guide, but I did not expect the two small components soldered to the end of the old cable. My replacement did not include them so I was forced to remove and reuse the old ones. My repair failed and I suspect it was because those two components were either bad when I started or ruined by my effort to reuse them. I’d try again but I have no idea what those components are and how to acquire new ones.
Steuman - Yanıt
Hi, I have not disassembled the image stabilizer during my teardown. I also reassembled the camera and gave it to a friend. I have added Step 19 with all my images, I had from the teardown. But this is all I can provide, I hope you will find a solution
Quanten -
Hello,
Were you able to fix your camera E62:10 issue ?
VMP Peters -
Any idea how to remove the pin that hold the battery door on? I assume the back has to come off, but then how to push the pin out the back is a mystery.
danzeitlin - Yanıt
Sorry, I haven’t disassembled the battery door
Quanten -
Thanks for this excelent guide!!
matiasrk - Yanıt
Thanks got everything working again after cleaning out the barrel. Only problem ow is the shutter button won’t take a photo? I guess I need to take all apart again and try to fix it.
Thanks
couldn’t get it back together without your photos
Ernie - Yanıt
Thank you for guide. I’ve also tried to repair. E62:10 issue. Without success. But I have additional images of stabilizer.
I’ve disassembled image stabilizer. Important parts are conductive tape with some Hall effect sensors and coils.
Coils and hall sensors are in place marked green. Coils are in stabilizer body and sensors on the tape.
Important point are marked red. There are connection points when coils are soldered to tape. When I removed tape I didn’t know about connection points and I cut the glue under the tape with connection wires. Then I’ve very gentle uncovered wires with surgical scalpel. Solder additional short wires to solder the tape.
https://flic.kr/s/aHsmLjSZPy
Mirek Sobczak
Mirek - Yanıt
part 2.
It is important to unsolder coils wires and remove solder before removing tape
I’ve ordered tape on aliexpress for 6$ for two pieces. I’ve used Hall sensors from old tape. I want to save 120$ (this is the price for reparation in some professional workshop in Poland).
Like I wrote at the beginning I’ve failed but maybe some one will find my images useful.
To author of this guide: fell free to add my pictures to yours teardown if you like.
Mirek Sobczak
Mirek - Yanıt
Is the image stabilisation cable moving/stretching while zooming? or it is fixed in one place? Because if it is not moving how can it micro-break by itself and cause the e:62:10 error as its being said on some forums.
Stefan - Yanıt
The image stabilizer is moving while zooming (it has a nib, see step 19, which is gliding in one of the three inner grooves, see step 17, last image) and therefore also it’s ribbon cable.
Quanten -
What type of shutter does hx400v have?
E E - Yanıt
I have added some detailed pictures of the shutter module. Looks like it is actuated with a (electro)magnet.
I hope it helps.
Quanten -
Hi there. I have a sony HX400v. LCD was intermittant, so have taken out the screen. The fault is with the ms c cable….it has a slight tear. Can this be fixed with super glue or tape? The screen is still functional but faulty, as obviously the movement causes intermittant contact.
Thank you.
Kim Donaldson
Kimdonaldson.1965@gmail.
kimdonaldson.1965 - Yanıt
Thank you, my friend, for the good instruction. I have the same problem and I tried to replace the ribbon feeding the stabilization system myself. I failed because the coil wires are covered with a solid mass (hot glue?) And it is practically impossible to desolder. Hall sensors are a separate problem. Kidy I tried to carefully desolder it, it fell into 2 parts. Unfortunately, I do not have replacements, so it was mainly the reason for the failure. Nevertheless, for those interested, it is important to pay attention to the 3 white balls on which the mechanism moves when disassembling the stabilization mechanism cover (an action necessary when trying to replace the belt). I just fell out and I was looking for them on the floor for a long time. In summary, the replacement of the tape in amateur conditions is not very possible. But for the persistent - maybe it's worth a try
Leszek Piątkowski - Yanıt
My pleasure, it is really nice to see, that this guide helps others.
Since the image stabilizer was not the failing part in my camera, I haven’t disassembled it further. It would be very cool, if you could take photos of the interior of the image stabilizer and add these to the teardown (even if some parts are missing, it is a teardown ;) ).
Quanten -
I have changes the optic but now the camera will not start.
I have checked every cable and they are all connected.
But when I push the on/of button, nothing happened
What could be wrong?
Kievit1964 - Yanıt
I have broken off the blue battery hold down lever. Can the Baseplate be removed (Step 11) without the prior steps, to then remove the Battery Case (Step 12)?
Bummers - Yanıt
I don’t think so. The baseplate, which covers the battery case, is sandwiched between the mainboard and the rest of the camera. Additionally there are many ribbon cables from the mainboard to the rest. I can’t imagine a disassembly procedure to remove the battery case without removing the mainboard and baseplate.
May put something between the battery and the battery case lid to hold the battery in place?
Quanten -
Gracias por la guía, me funciono a la perfección, a partir del desmontaje de los lentes fue complicado y todo lo ordene!, se me rompieron los cables de la bobina, el flexor del obturador, tuve que realizar reparaciones, pero finalmente remplace el flex del estabilizador y funciono, aun que se me olvido limpiar el lente y quedo con pequeñas basuras :(
Jonathan Mendoza - Yanıt
PD: Tenia error 62:10
Jonathan Mendoza -
Hi can you find a hack to make the camera do clean hdmi out?
CJ Hall - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 35
Son 30 gün: 165
Her zaman: 12,522
