Giriş
Xiaomi Mi Mix 2 is easy to repair. If you got your Mi Mix 2 broken by accident, you can repair it by yourself. This video show you how to disassemble Mi Mix 2 step by step.
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 14
Her zaman: 10,902
3 Comments
I wish this guide was step by step.
BootlegScarce - Yanıt
can I replace the battery without first removing the motherboard?
Danny Di clemente - Yanıt
I would like to recommend not to disconnect the signal cables unless it is absolutely necessary . The screen can be replaced whithout disconnecting them. I learned it the hard way ,once two connector broke ,one on the mainboard and another on the cable, I had to remove them and solder the cable directly to the mainboard
Albert Teix - Yanıt
