Ana içeriğe geç
Yardım
ring Stick Up Cam with Quick Release Battery Teardown
Adım 12 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Remove the two screws on either side of the power connector located on the top back of the ring camera enclosure using the PH2 tool.
Then using the Spudger Tool, pop of the rubber covers on either side of the power connector cover in the back, and pry off the power connector cover. This will reveal two PH00 screws that hold the external power interface to ring camera enclosure.
Remove the two PH00 screws on either side of the external power connector. Then gently using the Spudger Tool pry the external power connector from the ring camera enclosure.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
