Ana içeriğe geç
Yardım
Sony Cyber-Shot DSC-W120 Teardown
Adım 7 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Next, we're going to remove the shiny plastic panels on the sides of the camera.
The panel on the lens side of the camera is the easiest to remove. It simply slides toward the back of the camera and lifts off.
The right side panel is also quite easy to remove. Hinge the panel slightly towards the front of the camera and it will lift off easily as well.
Beware of the pink and blue wires that are soldered to the circuit board at the top of the camera. These connect to the flash capacitor and, even with the battery removed, they pack quite a punch. Be careful not to touch these or you will receive a pretty unpleasant shock!
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
