Ana içeriğe geç
Yardım
Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown
Adım 4 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Open the battery compartment of the Shaver Part begins with cutting the outer wrapping of silicone along the red line with a knife.
After removing the silicone layer you will see the internal battery compartment structure, next you just need to use a screwdriver to press down the metal part inside the red circle to remove the battery compartment smoothly.
It took me a long time to disassemble the razor section, which appears to have a molded case and was designed with the intention of never opening it again.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
