Ana içeriğe geç
Yardım
2 Slice Anko Toaster Teardown
Adım 3 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Now that most of the toaster's components are revealed we will start with removing the control panels. The control panels or PCB's are located in the upper shell of the toaster where you would usualy push your toast down. These PCB's are simply screwed in with screws. So unscew them and pull them out.
Now the top frame can be fully seperated from the bottom frame.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
