Ana içeriğe geç
Yardım
Microsoft Surface Book Teardown
Adım 21 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
The Surface Book features a "Muscle Wire Lock," that will keep your display securely fastened to the base, until it's time to undock and get more mobile.
Muscle wire is one of many names for shape-memory alloy, a class of materials that can undergo deformation, and then return to a prior shape when heated.
In this case, electricity is run through the wire, heating it up and causing it to contract. This pulls the black pulley inward, against the spring, lifting the lower arm of the linkage.
That lower arm holds a very tiny rod captive. The rod serves as the grip, that holds onto the base unit's metal tab. When the linkage is retracted, the rod rolls out of the way and lets the base go.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
