Ana içeriğe geç
Yardım
Samsung Galaxy Nexus Teardown
Adım 15 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Samsung Galaxy Nexus Repairability Score: 6 out of 10 (10 is easiest to repair).
Battery replacement is incredibly simple thanks to the removable rear panel.
Minimal adhesive makes removal of the motherboard and other components a snap.
Headphone jack and speaker assembly are not soldered to the motherboard, so replacement is easy.
The only soldered components are the volume switch and vibrator motor.
Removing the rear case to access the motherboard and other internals requires a lot of careful prying and guitar-picking.
The glass is fused to both the display and the display frame. So don't crack the glass unless you're good with a heat gun, or you're fond of replacing the glass, display, and frame together ($$$).
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
