Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Fans Are Not Spinning
The fans are either spinning at a reduced speed or not at all.
Poor Connections
If the fans are not working as intended, especially if it is only on one side, the connections may be poor. Try to follow the steps to ensure proper connection points for the fan. link
Defective Parts
If the blades on the fan are still not rotating after checking the quality of the connection, a fan replacement may be in order. link
Blocked Rotation
Ensure no dust or objects are disabling the blades from rotating properly. If the fans appear to be clear of all obstructions, there may be an issue with the wiring or connections and further inspection will be required. link
Speaker Is Not Producing Sound
The speakers are not outputting any sound.
Poor Connections
If the speakers are not working as intended, especially if it is only on one side, the connections may be poor. Try to follow the steps to ensure proper connection points for the speaker. link
Defective Parts
If the speakers are after checking the quality of the connection, a fan replacement may be in order. link
Speakers Are Making Unexpected Noises
The speakers are outputting strange or unexpected noises such as buzzing or thumping.
Dirty Speaker
Check to ensure nothing is blocking the speaker and that no dust or dirt has built up on the surface. If particles must be removed, a can of dust removal should be used to blow away the foreign objects. link
Broken Speaker
If the speakers are clean and properly connected, yet they still produce unexpected noises or distorted sound, they may be broken or “blown”. A replacement may be in order, especially if there is visible damage. link
Screen Is Not Displaying Properly
The screen is not displaying as expected. It may be black, distorted, or otherwise faulty.
Poor Connections
If the screen has a pixel that just stays on solid color instead of working with the rest of the screen, ensure the connections are proper to rule out wiring as the cause. link
Defective Parts
If the speakers are after checking the quality of the connection, a screen or display replacement may be in order. link
Incorrect Touchscreen Input
The touch screen is falsely registering input where it is not intended (the laptop thinks it is being touched where it is not).
Water On/Under Screen
If the touchscreen is registering input without being tapped, registering input in the improper location, or otherwise performing incorrectly, and the laptop has come in contact with water, there may be water damage or obstruction. Start by wiping down the screen with a cloth to see if that solves the problem. If the issue persists, a replacement may be in order. link
Broken Touchscreen Interpreter
If the touchscreen is registering input without being tapped, registering input in the improper location, or otherwise performing incorrectly, and there is no water damage, check the connections. If the issue continues, a replacement may be in order. link
Hard Drive Corruption
The hard drive has corrupted files
Overheating
If the hard drive is not properly cooled and ventilated, it may overheat and cause corruption. A fan replacement, in addition to swapping out the hard drive may be in order. link
Viruses
Viruses obtained from improper cyber security are common causes of hard drive corruption. Unfortunately, this is usually only fixed by replacing the entire drive. link
0 Yorum
