Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
If your Diswoe Switch-01 controller does not connect to the device when selected or doesn't appear as an available pairable device, follow this troubleshooting guide for possible solutions.
Not turned on
Your controller may be off. Check to make sure it is on, or try turning it off and on again.
Out of Range
Your controller may be too far from the device. Keep them physically close to each other to ensure your controller can be detected. It reports connecting up to 8 meters, but you may want to move closer to the console if you aren't able to connect.
Wireless device interference
Another wireless device with a conflicting signal may interfere with the controller's signal. Try turning off other nearby wireless devices before attempting to connect again.
Too many connected controllers
Most devices have a limit to how many wireless devices can be connected at once. Check if there is room for your controller to connect, or disconnect other devices.
Low Battery
Your controller may have low power or be completely dead. Be sure to charge your controller before attempting to connect it.
Battery is Dead
If your battery will not charge anymore, it may be time to replace it. Follow this battery replacement guide.
0 Yorum
