Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Screen won't turn on
Even though the device is on, the screen is still off or not functioning.
Dark Screen
First check to make sure the screen brightness is not at zero. Do so by pressing the function (Fn) and the F3 key in the top right corner of the keyboard at the same time. If this does not work, try pressing the Windows key and P at the same time. Try this once more and this will take the device out of presentation mode.
Cracked Screen
The screen has been cracked or damaged showing dark and white patches with some colored lines. To resolve this issue, consider replacing the screen.
Keyboard is unresponsive
After trying to input keys on the device, there is no response or an over response to input.
Keys Sticking
Keys are sticking to the device adding unnecessary letters to documents. For this, remove the key and clean the mechanisms to be sure there is nothing stuck.
Missing keys
The needed key is missing from the device making it difficult to use. To fix this issue, replace the keyboard.
Faulty Keyboard
If the keys on your keyboard fail to respond, consider replacing the keyboard.
Battery is defective
The device won't charge and cannot turn on without plugging.
Low Battery Life
When unplugged, the device will not turn on. First try plugging the device in and charge it. If the battery will not hold a charge, replace the battery.
It is also possible that the device is running too software at the same time. To resolve this issue, open the task manager by pushing Ctrl, Alt, and Delete at the same time. In the processes tab, end any unused tasks to preserve the battery life.
Battery Faulty
Battery is popping noises and loads of smokes. Unplug the device from the power source immediately if connected. Remove the battery as quick as you can to prevent any damage to the device. Dispose of the battery properly. Replace the battery using this guide.
Device won't work properly
Error messages keep turning on when starting the device.
Blue screen errors
If you see a blue screen error, restart your laptop. Press F8 before the windows logo appears. Use the arrow keys to select the Safe Mode from the boot menu. At the Advanced Boot Options, select Repair your computer. At the System Recovery Options window, click Startup Repair. If it does not resolve the issue, replace the hard-drive.
Hard-drive Failure
Loud scratching or grinding noise coming from the device. Check if the grinding noise is coming from the hard drive by using the hard drive diagnostic software. If the drive keeps making noise even when you use the hard drive diagnostic software, do a complete backup of your system and replace the hard-drive.
Device gets hot quick
The device is unusually hot and is making it difficult to use.
Ventilation Fan Failure
If the device is being not on a flat surface, proper venting will not occur. Move to a new location to fix this. Be sure that all vents are clear of debris using the compressed air can. If this does not fix the issue, replace the fans in the device.
Audio is distorted
There is no sound coming from the device when audio visuals are played.
Missing Audio
There is no sounds coming from the device. On the top of the keyboard and towards the middle, there are 3 different keys with speaker symbols. The one on the left mutes the computer, middle lowers volume, and right raises volume. While holding the function (Fn) key, press the mute key once. If this does not work, repeat the last step, but this time press the volume up key instead of the mute key. If neither function works, replace the speakers.
Audio fades in and out
Audio coming from the left of the device is not the same as audio coming from the right. To solve this issue, begin by right clicking on the speaker icon in the bottom right corner of the screen. Click playback devices. Click speakers. Click properties. Click the advanced tab on the properties window. Change the default format drop-down to the highest quality. Apply the properties.
Click OK to close the properties window. Restart the device, and test the sound. If this does not work, replace the speakers.
3 Yorum
My hp omen pc is in this audio repair for almost a month
what do I do??
Stuart Hall - Yanıt
My touchpad on my omen won’t work. Have to use a plug in mouse to move. Even geek squad can’t figure it out
Sean - Yanıt
My laptop woun't turn on at all but when plugged in it shows(from the light on the side) that it is charging.
Polycarp Francis - Yanıt
