Ana içeriğe geç
A powerful workstation laptop that fits into a portable package. Has multiple ports and connectors for a portable work environment.
7 Soru Tümünü görüntüle
Why my laptop batterie does not work?
Hello,I have an HP Elite book and The battery does not work as usual I need to keep the charger connected to the PC or it will turn off
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
if your battery is not charging on HP laptops, before replacing parts and get your electronic weapons out... try to disconnect all cables, remove battery, press power button for 15-20 seconds, it will flush the "battery memory", plug everything back and power on, ...charging and working :)
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
boutaina, make sure that your battery makes proper contacts etc. otherwise I'd suggest you replace it.
Puan 0
Yorum Ekle
HP batteries are one of the worsest on the market ... when u dont need a battery just take it out ,that way you will extend its life , and ur notebook will have better performances ...
Puan 0
Yorum Ekle
If the new battery also not charging means you laptop charging circuit may be got fault
Puan 0
Yorum Ekle
Yanıtını ekle
boutaina sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 2,276
