Ana içeriğe geç
Sound but no picture?...
Hi
I havent seen this one crop up in any threads so far. Sometimes my XBOX 360 starts up with only sound (no picture). One green light on console, no reds.
Changing cables doesnt make any difference. Checked for loose cable connections in back of TV and XBOX and all fine. I've used th etowel trick about 4 times now to 'reset' the XBOX and this works but it now a matter of days before the same problem arises, and I dont want to keep diong th etowel trick in case it makes matters worse.
Will re-doing the Heatsinks with Thermal compound be a worthwhile venture for this problem?
Thanks in advance for any useful advice...
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Rob, this most certainly sound like an overheating issue. I suggest to not do the "towel trick" any more. The issue is that it will cause way more problems (trust me, been there:) I would at least try to get the RROD fix kit and install it, using this guide. Yes, thermal compound may help, but I think it will need a bit more work. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Rob sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,139
