Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Soru Tümünü görüntüle
Camera shutter will not open.
Ok so after replacing the front and back glass covers and replacing the camera I have been unable to use the camera app as the virtual shutter will not open.
I have tried covering the camera's, cancelling the app in the background run bar, soft and hard reset, settings>general>restrictions disable-reset-enable camera and all possible combinations of the above methods with the original camera (that worked before case replacement but was dirty) and and the new replacement camera.
Reading further about damaged jumper points on the logic board ( http://www.gsmindia.in/forum/apple-iphon... ), I have opened the device and inspected the logic board. Both sets of points seem to be intact for front and back cameras. I then checked for continuity in the jump points from the first picture (points near the front camera), and then the points from the second picture (near the rear camera) with a multimeter. The first set seem fine however the second set gave a high impedance (~100Ohm) in both directions. Should I remove the connector at the second point set and jump it with a solder bridge? Is there anything I'm missing?
Front camera points.
http://www.technicalnet.ch/iphone/Frontc...
Rear camera points.
http://s9.mojalbum.com/15043899_16472183...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
3 Cevap
Filtre ölçütü:
As long as both resistors are still intact on the logic board, it's probably going to be either one of the cameras. Will the shutter open if you open the camera app through messages?
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I think it's a bad idea. The logic board that you are seeing on these images are water damaged boards. So the values are maybe not good.
In this case I think the problem comes from Camera flex, maybe they're cut anywhere (micro-cuts). For my part, you have to change the camera and make cross test.
Puan 0
Yorum Ekle
iam unable to open my camera after all tries is there any hard ware problem in my iphone 4 16 gb
Puan 0
Yorum Ekle
Yanıtını ekle
Josh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 4,209
