My iPod got washed
Hi i unfortunately washed mi ipod in the laundry. But when connected to the computer, I can load and download the contents but I does not want to switch on Any help!!!!!!!!!!
Bu iyi bir soru mu?
Bu iyi bir soru mu?
fabrice, here is my answer from a similar question."Do a search on here and you will find that you are not alone. Anyhow, the repair of this is tricky, due to the size of this device. The first thing that I would do is try to disassemble it right down to the logic board. Use this guide. Once you get it to the point, disconnect the battery. Clean the logic board using this this as your guide. Once you have it cleaned, replace the battery with a new one. It might be tough to \find it, but use the number on your battery as a starting point for a search. This is a difficult repair, but take your time, read the guides, and you will get it accomplished." Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
you should not switch on until you dry it up. use a hair dryer. also read and follow tips from below articles:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,130
