No power - makes a popping sound - fails to turn on.
Hello,
I have 3 (three!) 3DS systems that have the same problem. When you press the power button, the blue light turns on for a second, and then the screen flashes with a popping sound and the system shuts off.
Any idea on what's going on here? I read something once about a fuse, but that was long ago.
Thanks,
Andrew
Bu iyi bir soru mu?
47 Yorum
i'm having the same issue as andrew had, my 3ds after i turn it on, it shuts off in 3 seconds, before it made popping sounds, when i dropped it, it was fine, except that the brightness on the top screen was more like a five, i really need help on this, if anyone had the same problem and got theirs fixed without calling nintendo, please help me out here.
wes smith tarafından
I have the same problem, except at random moments during gameplay it makes a popping sound, goes black, then resets the time. I think I figured out how to make it stop (by not moving the top screen while playing) but when I move it, it resets. Gets kinda annoying, especially playing games when you need to tilt it or move it around.
Tris Prior tarafından
I have the same thing are there any ways to fix it I even charge it and it won't come one
Mcglavalo tarafından
nintendo have fixed this but u either have to replce top screen or bye a newer 3ds
oisin tarafından
I have the same issue. I have taken the 3ds apart but all ribbons seemed to be seated well and there doesn't seem to be any tears in the ribbons. The only thing I noticed was the WiFi antenna is torn a bit. In all fairness I don't remember if I tried it with the WiFi off. Could the WiFi antenna cause this issue?
DJ Hotnisky tarafından
42 tane daha yorum göster
