Ana içeriğe geç
Droid Razr, Motorola tarafından tasarlanan, Android tabanlı ve 4G LTE özellikli bir akıllı telefondur.
How to fix water damage
dropped in toilet, 2 weeks later, battery removed, lots of corrosion evident under battery. video posted on you tube showing use of a toothbrush to try and clean contacts, but this does not seem to have worked. any suggestions?
Bu iyi bir soru mu?
Puan 3
1 Yorum
hi, okay omg this is my moms boyfriends WORK phone and he leaves everyday for work at about 5:30 AM so . i need some urgent help and assistance hes gonna kill me once he finds out , im already f***ing up with other things around the house... i dropped it in the toilet and did the worst possible thing to do as soon as you take it out of the water. i thought there was a way to open the back but dang it has a friggin mother board i need help please,
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes here are some suggestions, use these methods to clean your water damaged phone, its done on a Iphone but the methods apply to your phone,Here is a guide to teardown your phone, Motorola Droid RAZR Teardown , if you follow these guides you should be able to fix your phone as long as the toilet dive didn't happen Eons ago, good luck and keep me posted, If this answer was helpful please remember to mark it accepted.''
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
I recommend using crystal cat litter as a desiccant to dry everything out while you have it disassembled. Just wrap the parts in some thin cloth & bury it in (unused) crystal cat litter. It is basically the same thing that comes in those little "Do not eat" bags packed with all electronics.
Puan 1
Yorum Ekle
I was able to do this. I let the phone dry out after a full trip through the washing machine. At first, the phone didn't work at all, then gradually started working a little. The batter was completely dead. Most functionality came back once I replaced it (put in a Maxx battery while I was at it; note to persons who do this: get a new loud speaker in addition to the kit as the old one wont come out of the old housing without damaging it and I had to do this - I recommend this for water damage repair as well as you get the benefit of a bigger battery and new water damage detection stickers). The sensor bar (home buttons etc) didn't seem to work right; the menu button kept pressing itself (guessing there was a little water left in there), but this eventually righted itself (it took like 2 months). The vibrator didn't work very well (I haven't replaced this yet as the replacements are hard to find), but it worked a little (you could hear it trying to vibrate). Both cameras, and the flash were non-functional. I have since replaced them and they now work again. You may also want to get a new "1080p" sticker bard as you will likely break it in dis-assembly and you may want to get a couple water damage stickers if you wanna make it look pristine. So, summary: you will need this guide, a front and back camera, a razr maxx upgrade kit, a loud speaker,a flash module, a "1080p" sticker, at least 1 water detection sticker, a vibrator motor, an "iphone repair kit" or a lot of small hex tools and 2 spudgers and a lot of patience and time. Repair beginning to end took about 2 hours just from begin careful and patient and having tiny parts. If you have or can get an esd bracelet, I recommend that too. Totally fixable though, if you are careful.
Puan 0
Yorum Ekle
Hey mark, I would like to answer in your post. There are several ways through which you can repair water damage. the best one is hiring a professional water damage repair service.
It is quite easy to fix water damage; it comes down to one or two things. Call a plumber or do-it-yourself. There are several companies which provide water and fire damage repair services. I would like to share some very good options with you.
http://www.dallasplumbing.com/
https://bestplumbers.com/
http://www.restoremax.us/
Puan 0
1 Yorum:
this is a add bot
tarafından
Yorum Ekle
bonjour mon téléphone cassé i besoin de son il ne fonctionnera pas humide et
Puan 0
Yorum Ekle
Bonjour,
T'inquiète ,moi aussi ce téléphone RAZER je conseil a personne de l'acheter , j'ai eu un remplacement de mon cellulaire au cause de son et le cellulaire que j'ai reçu c'est pour la poubelle.
Puan 0
Yorum Ekle
Yanıtını ekle
MARK SADA sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 37
Her zaman: 37,004
