Ana içeriğe geç
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
Procedure on how to clean the Logic Board with isopropyl alcohol?
I have a MacBook Pro 13 2011, how I proceed with cleaning the logic board which was subject to water damage?
And how do you precede with cleaning? Using cloth or how?
Saw a topic on this page Cleaning a logic board......
Thank you
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here's the guide for doing this: Electronics Water Damage
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Aslamualikum dear brother i used mother bord cliner fine product
Puan 0
1 Yorum:
Hello Brother can you pls help,need advice
tarafından
Yorum Ekle
Genius Guy, recommend you first open your system and get 99% alcohol to clean the board, dont be scare to take a pane with alcohol and clean the board using a tooth brush getting wet the board it will be ok for Apple boards but not for pcs, leave it for 20 mins, alcohol is acting under chips, then blow it up with regular compressed air, if you are in a hurry blow it up after with hot air, make sure you dont create static electricity, then wait for one hour inspect board again before turn the computer on again.
Puan 0
1 Yorum:
HI need help , i spill hot milk in to mother board , if i clean as u said its will work and won't damage the board.
tarafından
Yorum Ekle
Yanıtını ekle
Martins Strobinders sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 30,347
