Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2193 Soru Tümünü görüntüle
Will I need glue when reassembling an iPhone 4S?
I have to change the display assembly in my iPhone 4s, because someone stepped on it and the glass is completely shattered (the screen and touch work perfectly though), so I read the tutorial to see if it the repair was too hard for me.
Apparently it isn't, but I noticed that during the disassembly of the phone, almost everything with adhesive gets separated from it's base (Vibrator, Battery, etc.), it seems as if the glue stays in it's place, but I don't know if it's dry and needs reapplying.
Will I need to use adhesive to place these parts back in?.
If so, What adhesive would you recommend?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
No. You do not need adhesive or glue to rebuild the iPhone 4S during repair of the front screen assembly. If the glass is shattered so much you can even remove the screen adhesive, to help remove the glass shards from the midframe. This adhesive does not need to be replaced, just do without adhesive.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
No, I almost never need to add any adhesive, if at all maybe to the vibrator but no worry's there is a screw that also holds it down, iPhone 4S Screen Replacement, good luck, If this Answer is helpful please remember to return and mark it Accepted
Puan 1
Yorum Ekle
I have a feeling that the adhesive also acts as a Vibration blocker --- my Screen replacement works for both 4 and 4s perfect but I feel the phone vibrates more than it should when calls are active ... anyone knows anything about this?
Puan 0
Yorum Ekle
Yanıtını ekle
Alberto Delgado sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,928
