Ana içeriğe geç
The Motorola Droid RAZR Maxx is a version of the Droid Razr carrying a higher capacity 3,300mAH battery.
23 Soru Tümünü görüntüle
end of head phone jack broke off in phone
was listening to music via head phones, into the headphone port.
when i went to pull the headphones out of the port, the end broke off and i am unable to reach it. if i take the phone apart, will i be able to get to this broken part and pull it out?
Bu iyi bir soru mu?
Puan 18
20 Yorum
This worked!!!!!!!!!!
tarafından
This didn't work, nothing against you, it just pushed it in a LOT more
tarafından
Help me this didn't work what do I do now
tarafından
Thanks it worked. I put the super glue on the interior bit of the broken jack (wiped clean the outer bit), pushed it inside, waited for an hour to dry and then yanked it out with fingers crossed. The whole thing came out as one.
tarafından
I tried the glue method and it did not work for me, now it seems that the piece is glued into my ear jack. Any recommendations please!!
tarafından
15 tane daha yorum göster
Yorum Ekle
21 Cevap
Filtre ölçütü:
Seçilen Çözüm
Take a BIC pen ink tube, insert the tube to the headphone jack and plug the broken tip to the tube and just pull it out, it worked just fine for me, hope you can find this useful.
Bu yanıt yardımcı oldu mu?
Puan 25
28 Yorum:
Just tried this on my S7 and it worked like a charm thanks for the advice
tarafından
This is an awesome idea. My fiance broke one off in his charge port and we've tried everything we could think of, we will be trying this later!
tarafından
This Works!!
tarafından
The BIC Pen instructions worked, GREAT! Merry Christmas,
tarafından
Easy peasy. Worked perfectly.
tarafından
23 tane daha yorum göster
Yorum Ekle
this is what i do and it works very well.
try to put a small amount of superglue on the broken end and stick it back in your phone. hold it and let it dry then try to pull it out.
if that doesnt work then take a paperclip straighten the end of it. then hold a lighter underneath it till it is red hot. then stick it in your phone jack and it will melt the plastic and bond to the broken headphone piece so you can pull it out. this method works for me very well
Puan 3
5 Yorum:
Can u do it with gorilla glue or is a different kind
tarafından
Thank u really helped got it out
tarafından
Wow!! My daughter broke the headphone jack in my phone and I was sure it was ruined. I tried the superglue trick and I couldn't believe it worked!! When I first put a dab of glue on the main headphone piece and put it in the phone, I left it in for about 25 seconds and when I pulled it out, it was not fixed, and the glue made it seem as if it wasn't going to come out at all. I put the jack back in, twisted it a bit, pushed in and everything came out in one piece. Absolutely thrilled!! Thank you so much to The PIcklefish!!
tarafından
Thank you so much! Been trying to get a piece of plastic out of my earphone jack all day. Then I heated a safety pin, inserted it into the plastic, waited and pulled it out! So simple! Thank you for sharing!
tarafından
Bad thing i don't have paper clip and lighter
tarafından
Yorum Ekle
I was listening to music and I set my phone in my pocket and I must of moved wrong and the jack of ear phones got suck in my phone so I took a pin cartridge and put it in the hole then I pulled a piece of it out but there was still some in there so I took some small nettle nose plires and in a sideways motion I took the pliers and pulled it out so basically I dug it out but be careful it could mess up your phone
Puan 2
1 Yorum:
That’s unlucky
tarafından
Yorum Ekle
Ifixit makes a tool for just this problem...
GripStick Headphone Plug Extraction Tool
GripStick Headphone Plug Extraction Tool Görseli
Ürün
$19.99
Puan 1
2 Yorum:
Well, is it worth buying if the piece has been pushed in as far as it probably possibly go after trying every other method?
tarafından
Yes, the GripStick would be specially helpful in that situation.
tarafından
Yorum Ekle
Take a cheap BIC pen and take the ink cartridge out. Then put a small amount of hot glue into the end opposite of where the writing part of the pen is. Quickly insert into the the jack and press for 10 to 15 seconds. Now pull the cartridge out.
It worked for me
Puan 0
Yorum Ekle
You can use any glue hold it down on the thing you trying to get out for 5 minutes and it comes right out but u can only pull as fast and risk it or go as slow as you can and nothing so have fun wish u the best The end
Puan 0
2 Yorum:
I used the glue didnt come iut now really stuck! Any ideas?
tarafından
i dont want glue in my phone but if it works it works, but idk if it works so someone tell me ok.
tarafından
Yorum Ekle
I got the center part of a pen which was too small to do the first method then melted the plastic with a lighterand stuck it in. I waited a while then pulled it out and it worked! So happy.
Puan 0
Yorum Ekle
I think the best way is to use a needle,birthday badgeetc stab it into the rubber part then yank it out it worked for my apple earphones.
Puan 0
2 Yorum:
I've put my apple headphones it to my iPhone se and I pulled it out and it snapped I've tried all the ways above any other suggestions ?
tarafından
My grandma could’ve thought of that
tarafından
Yorum Ekle
All of these above are very good but most are for if you can risk damaging the headphones port. I have a broken off end of my headphone stuck in my £700 laptop. I really don't want to ruin the audio port so is there any safe and easy way to remove it
Puan 0
1 Yorum:
Most of these above are good but are they because most of them involve glue and if the glue sticks to the audio port it could be stuck in forever and for my problem I can't risk ruining my device. The end of my headphone broken off in my £700 laptop and I don't want to try a way with glue to get it out so I need the safest and easiest way to remove it.
tarafından
Yorum Ekle
Görsel içeriğini görün:
Puan 0
3 Yorum:
Wonderful getting to know everyone hi I’m Marcus Rashford and I play for Manchester United
tarafından
I’m a billionaire
tarafından
so am I dude.
tarafından
Yorum Ekle
I’m loving my life living in a mansion playing for Manchester United it’s my dream I’ve also got a Lamborghini Adventador
Puan 0
3 Yorum:
nobody cares'
tarafından
Forget to switch accounts?
tarafından
did i ask
and also idk y i wrote this i am just tired so reading this was sad
tarafından
Yorum Ekle
Just use the end of a pen tube and force it into the end of the broken headphones. If it’s too big then bite the end of the tube push it in again and pull it out really fast. This worked for me. Hope this helped!
Puan 0
Yorum Ekle
Tried the glue method and it's worse. I am trying the bic pen and now it seems too tight and impossible to remove. Any ideas?
Puan 0
Yorum Ekle
Use a nail cutter (a big one if necessary) and position it to the end/tip of the nail cutter, pierce into the stuck earphone jack and yank it out! Hope this works!
Puan 0
Yorum Ekle
I'm having this situation right now. I managed to get the brass cover off with a safety pin, but the broken piece is still stuck. Any ideas or am I screwed? I just got this laptop at Christmas as a gift
Puan 0
Yorum Ekle
Get a GripStick from here:
http://nightek.com or iFixit
Puan 0
Yorum Ekle
How do you get a pen ink tube from a BIC pen like how do you open the pen
Puan 0
1 Yorum:
oof that is sad but u r lucky because i still cant find a pen, poop.
tarafından
Yorum Ekle
I broke my jack into a point where a normal method is useless, its not at the end. Its the midpoint, so the pen thing is too small. I need help so any suggestions.
Puan 0
Yorum Ekle
At CareProdx, we offer best in industry ADA door opener, bariatric & wheelchair supplies, handicap equipment and much more. Visit our handicap supply store now!
Puan 0
Yorum Ekle
Umm question, why can’t we solve all our problems by going to a place where they do it for you, and you don’t screw up your phone/laptop. I mean ya it cost money but what if you mess up you laptop or phone when your doing these hacks then what, I’ll tell you 700 dollars down the toilet.
Puan 0
Yorum Ekle
I am unable to remove jack of broken handfree from my mobile .It's LG LS620 and Jack is stuck till far end of phone.I have tried all i could but nothing works
Puan 0
Yorum Ekle
Yanıtını ekle
Charlotte sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 123
Her zaman: 123,705
