It said iPhone disabled connect to itunes
It told me to unlock it
Bu iyi bir soru mu?
toby gray, put your iPhone in DFU mode and Restore with iTunes:
Connect your iPhone to your computer
Turn your iPod off
For 10 seconds, hold both the Home and Power buttons
While still holding the home button down, release the power button only Continue to hold the home button down for an additional 10 seconds. After the dialog box explaining that the iPhone was found in recovery mode has been closed, restore your iPhone. Bad part with this is that you are going to erase the information that has been collecting on your phone since the last backup. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
thank you so much for the helppp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! it took me so long to find the answer and i looked it up on google and this website popped up and it was soo so so so helful, agian THANK YOU!!!!!
you can also just power off the device and hold home button down as you connect it to force it into recovery mode, and then restore with itunes... again all data will be lost , this is easier than DFU mode
thank you soooooooooo much!!!
tnakyou so much for your help
Connect your iPhone to a windows laptop or computer.
If that doesn't work then try something else.
I really hope this works for you guys because it definitely worked for me.
Turn your iPod off
I am trying to unlock my mom's iPhone 4. She passed away a year ago. I tried different things and now it says "iPhone disabled connect to iTunes ". Tried that and did not work! I really need some help here. Trying to get this done and give it to a cousin who is down on his luck and needs this phone. Thanks in advance!!
It's disgusting that apple did this, such a critical issue with data stored getting lost. I surprised
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 24
Her zaman: 36,349
10 Yorum
my iphone3gs is lock
rian smith tarafından
My iPhone 4 is lock
ewunner46 tarafından
I have a A1303 Apple IPhone and it is locked on Connect ti iTunes and showing USB CONNECT TO LAPTOP. Before I open it, it state iOS6 ?? I have held both the home and power button down for 10 sec after turning the iP off and releasing the power button after 10 secs but nothing happens.
kerry tarafından
i phone is disable to connect itune
Maruti Jadhav tarafından
iphone is disabled
how i do open this lock
abdullahyaseen789 tarafından
5 tane daha yorum göster
