Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Soru Tümünü görüntüle
It said iPhone disabled connect to itunes
It told me to unlock it
Bu iyi bir soru mu?
Puan 60
10 Yorum
my iphone3gs is lock
tarafından
My iPhone 4 is lock
tarafından
I have a A1303 Apple IPhone and it is locked on Connect ti iTunes and showing USB CONNECT TO LAPTOP. Before I open it, it state iOS6 ?? I have held both the home and power button down for 10 sec after turning the iP off and releasing the power button after 10 secs but nothing happens.
tarafından
i phone is disable to connect itune
tarafından
iphone is disabled
how i do open this lock
tarafından
5 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
toby gray, put your iPhone in DFU mode and Restore with iTunes:
Connect your iPhone to your computer
Turn your iPod off
For 10 seconds, hold both the Home and Power buttons
While still holding the home button down, release the power button only Continue to hold the home button down for an additional 10 seconds. After the dialog box explaining that the iPhone was found in recovery mode has been closed, restore your iPhone. Bad part with this is that you are going to erase the information that has been collecting on your phone since the last backup. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 16
4 Yorum:
thank you so much for the helppp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! it took me so long to find the answer and i looked it up on google and this website popped up and it was soo so so so helful, agian THANK YOU!!!!!
tarafından
you can also just power off the device and hold home button down as you connect it to force it into recovery mode, and then restore with itunes... again all data will be lost , this is easier than DFU mode
tarafından
thank you soooooooooo much!!!
tarafından
tnakyou so much for your help
tarafından
Yorum Ekle
Connect your iPhone to a windows laptop or computer.
If that doesn't work then try something else.
I really hope this works for you guys because it definitely worked for me.
Puan 5
Yorum Ekle
Turn your iPod off
Puan 1
2 Yorum:
I am trying to unlock my mom's iPhone 4. She passed away a year ago. I tried different things and now it says "iPhone disabled connect to iTunes ". Tried that and did not work! I really need some help here. Trying to get this done and give it to a cousin who is down on his luck and needs this phone. Thanks in advance!!
tarafından
It's disgusting that apple did this, such a critical issue with data stored getting lost. I surprised
tarafından
Yorum Ekle
Yanıtını ekle
toby gray sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 24
Her zaman: 36,349
