Ana içeriğe geç
2009 yılında piyasaya sürülen giriş seviyesi Photosmart yazıcı. Tek kullanımlık baskı kafasına sahip HP Üç Renkli mürekkep kartuşları kullanır.
Loud ratcheting noise from printer
When printer initializes before printing, a loud ratcheting noise comes from beneath ink cartridge carrier for several seconds.
What lis likely cause?
Bu iyi bir soru mu?
Puan 5
2 Yorum
I have checked everything. There is no paper jammed. I have removed the ink cartridges and reset them. When I look inside with a flashlight I can see (off to the right hand side) a little black piece connected to a spring that vibrates back and forth against the carriage and this is what is causing the noise.
tarafından
I have the same problem but I found out that when printing A4 borderless from the application menu but the Printer Setting is A4, the sound occurs each time a page is printed. When printing a .PDF document in A4 it always skips part of the document. When A4-borderless is used, the print is OK but the grinding sound is present. When I set A4-borderless also in the Printer Settings, the grinding disappears. I use Linux Mint 18 and HP usually is supported well for Linux. Yes, the ink is only for sale when paid in gold bars...:-(
Cheers
Pjotr1950
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
I have this printer at home!! It made those noises for me as well until I cleared a jam in the paper slot. Also make sure all gears are still working and ensure there is no excess paper floating around. Go to the backside open the door and just give it a good cleaning. Also take out the ink carts, and put them back in making sure they are flush.
Bu yanıt yardımcı oldu mu?
Puan 4
3 Yorum:
I'm keeping an eye on you flo. You seem to know your stuff ;-)
tarafından
^.^ I do this for a living now, so when the shop is slow I answer what I can, its a learning experience as well!
tarafından
We've had this for a few years on an HP3520. The cartridge carrier is rattling back and forth. It doesn't seem to affect tge printing, but ink leaks out of the bottom of printer.
tarafından
Yorum Ekle
On this model make sure you clean the encoder strip that the print head slides through. It gets excess ink on it and loses its way. Also check the printhead bottom to make sure it isn't coagulated at its base.Always brush the drive gears with a clean tooth brush. ( Best cleaning solution is a windex mix )
Puan 2
Yorum Ekle
Cleaned the glass very carefully twice…no improvement. removed and replaced ink cartridges…no improvement. unplugged and replugged..took an hour off for attitude adjustment….. removed power… rotated printer …opened rear panel to view paper feed operation. …examined light dust….printer now fed normally. Replaced rear panel..operates normally. Apparently I accidentally fixed it *S*.
Puan 0
Yorum Ekle
This is my second HP5520 printer. The first one made grinding noises after about 2 yrs. Kept making noise until it quit. Had to buy the same model because I had so many ink cartridges left. Well, her I go again. This one is grinding and won’t pick up paper. I’ve cleaned everything, didn’t find any broken pieces but it just won’t pick up. I love this little printer, when it works. I’m off the buy another one. HP is still the best printer, maybe I’ll spend more this time.
Puan 0
Yorum Ekle
I have a Photosmart C4780 here doing that loud ratcheting noise when you turn it on etc.
Found the issue is likely due to a broken bushing on the lower right hand side near rear that supports the paper feed shaft.
Can manually move the shaft up and down a bit, and seems to have some broken plastic in that area.
A cleaning of the encoder strip, and calibration seems to have made it less, but the unit prints, scans and copies ok. So run it till the wheels fall off.
Puan 0
Yorum Ekle
Yanıtını ekle
Chuck sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 26
Her zaman: 16,763
