Ana içeriğe geç
Tüm üreticilerin ve servis sağlayıcılarının telefonlarını onarmak için bu kılavuzları kullanın.
73637 Soru Tümünü görüntüle
Soru Kapandı
which are the components that are damaged more frequently?
Hello, my question is about the motherboard of a mobile, which are the components that are damaged more frequently? There is any way to separate them from the others components? This could made the device more repairable. If possible is it worth it???
Thanks you!!!
G.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Giovanni Riva, that all will depend on what type of damage and what model device. Water damage can most certainly ruin most components on any board. It will depend on if it was powered on or off when it susrained the damage. Of course, current carrying components will shorten out quickest. That is the reason for not turning on the device and to remove the battery. Dropped damage will most certainly damage the LCD's, the battery, crack the logic board, and tear the cables. As you can see it all depends....:-)
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Ok, understood!!!
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 106
