Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Soru Tümünü görüntüle
Why does my iPhone only work on the charger?
I dropped my iphone and it cracked my front screen. i thought it was okay because it still worked perfect. But the next day i was getting somthing at walmart and my iphone fell out of my pocket and hit the floor. ever since that happened the only time my phone works is on the charger. is this the charger port or the battery? help?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
1 Yorum
feliciabaird1995, this will be a guessing game until you disassemble your phone and take a look at the components. Like Alissa suggest, start with the battery and its connections.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If it was the charging port you wouldn't really be able to use it while it was on the charger... maybe check the battery connection.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
more than likely it's your battery. In some cases the logic board could be at fault (have a bad capacitor - basically +/- battery terminals are connected due to the the bad capacitor)
Puan 0
Yorum Ekle
I had the same problem. when I opened up the back It turned out that my battery was not connected right. Maybe that's the problem you've got.
Puan 0
Yorum Ekle
Yanıtını ekle
feliciabaird1995 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,864
