Ana içeriğe geç
Soru Kapandı
After Replacing HD the Fan is Always on
I replaced the original 120 gb 5400 rpm drive which was making a lot of noise in my A1226 with a 320 Gig Seagate 7200 RPM drive. Since that time the fan runs constantly from Boot. Before this, It would run depending on how hard the CPU was running, but now if everything is Idle the fan will still runs.
The only thing I can think of is I did not do a clean install on the new Drive I just copied off a Super duper archive, but I may be wrong about that.
Any thoughts?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Did you connect the heat sensor back on logic board?
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I didn't remember taking it off. I did just check the Hard drive replacement instructions and the Heat Sink Replacement instructions and the Sensor Cable is nowhere near where I was working, unless thre is another cable I don't know about.
tarafından
Try this
http://support.apple.com/kb/HT3964?viewl...
or this
http://support.apple.com/kb/HT1379
At last try AHT (apple hardware test) and tell us what errors is giving.
If nothing instal smc fan control and adjust minimal rpm manualy
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 2,524
