What would cause a liftgate to not unlock. All fuses are good.
Liftgate will not unlock.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Replace the ECC fuse 10 amp in the instrument panel fuse box just to be sure it's working, this powers the liftgate. Here's a teardown of the problem and possibly how to fix it:
Read more: http://www.justanswer.com/questions/21db...
Bu yanıt yardımcı oldu mu?
Hers an additional fix for the problem. Ralph
I had the same issue and I replaced the ECC 10A fuse which fixed both my liftgate locking and rear air to start blowing again. However, the fuse blew again in less than a day.
Mine is doing the same. Did you ever fix yours?
For my 2006 GMC Yukon I cannot find the specific place where my ecc 10 A fuse is? Can anybody tell me?
Where is it located? There are three fuse boxes on these trucks.
Dears ,
You can change the machine of lift gate by normal center lock, like this :
It's comes with small rule you'll fix it by any hall on the body it's and connect the two wire with the original harness.
Only need to make small hall on the plastic to make it lock or unlock the lift gate and remove the gear from the original machine.
Son 24 Saat: 14
Son 7 gün: 37
Son 30 gün: 90
Her zaman: 74,955
1 Yorum
Can you give us more information? The liftgate is electronic?
Kyle Wiens tarafından
