Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2193 Soru Tümünü görüntüle
Small water intake, now wont charge or connect to itunes
A few days ago some water was spilt on my phone and now it wont charge or connect to itunes. ive done a hard resta few times and still the same. should i repalce the dock connecter part?
Thanks
Bu iyi bir soru mu?
Puan -1
8 Yorum
Hi old turkey and thanks for you reply, I have got a bottle of surgical spirt and it ingredients are 95% methylated spirts. 2.5% caster oil.. Can I use this? Thanks
tarafından
I would not due to the oil.The isopropyl alcohol is to clean and to displace any water and it is not conductive to electricity.
tarafından
Yeah I didn't think it would be a good idea after u posted the comment, I'm having trouble souceing isopropyl locally in the uk. I think I wil
Have to order it online. Thanks for your help
tarafından
Check with your local pharmacy, I get mine through those.
tarafından
yes have done, told me they do not stock it.. is nail varnish remover similar?
tarafından
3 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Adam, it does not really matter how much water was involved, it will depend on where it got into the phone and if it shortened out any of the SMD components. The very first thing you want to do, is to clean your phone. This will prevent failure caused by corrosion late on. The procedure for cleaning your iPhone is pretty much the same. Use these guides to work on your phone. Disassemble it and clean it using this guide. It was written for a 3G but all the points are still pertinent to your phone. Use 90%+ isopropyl alcohol to clean it. Once you got it cleaned, replace the battery and reassemble. Then re-evaluate for further, if any, damage. Yes, it is "possible" that this is cause by your dock connector, but also by numerous other possibilities. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Adam sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 148
