Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Soru Tümünü görüntüle
iPhone 3GS vibrator do not work,
Hi, I have an iphone 3gs 32 gb, i replaced the back housing and the glass screen, everything works but the vibrator, it works fine from setting also I removed the motherboard and installed anotherone and it works just fine. Obvious is a mother board problem. How can I fix it?
Bu iyi bir soru mu?
Puan -1
1 Yorum
sergio cortez, what exactly do you mean when you say "it works fine from setting " Does that mean you had the vibrator working?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi sergio,
For sure, it could be a motherboard problem. However, I would first check on the two pads of the motherboard on which the two vibrator pins are pushed when the motherboard is secured.
Use this teardown guide and take a closer look at step 12. You find the two pads for the vibrator motor to the right of the notch at the buttom of the picture. Is there anything unusual or strange?
Steffen
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
sergio cortez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 125
