Where exactly is the Flasher Relay for a 2003 Mazda Protege located?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Berry, the Turn signal/Flasher relay is under dash on drivers side. If you have a manual transmission is is almost directly above the clutch pedal. It is a gray colored box about 2 inches wide by 4 inches long. It is #5 in the attached diagram.
Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Thank You very much , it solved my problem.
Thanks
Ronald (Philippines}
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 23
Her zaman: 11,377
1 Yorum
Thanks oldturkey03! I will check this out immediately.
Berry tarafından
