Ana içeriğe geç
This receiver is Bluetooth Ready, has 110 Watts x 5 Direct Energy Amplification and is iPad / iPhone Certified with supplied cable
No Power - not surge related
Used this receiver one day, the next it was dead. There was no power outage or surge. There is no display and not responding to the remote or switch. Checked all the power components and they appear to be okay. Getting power to the unit, but not going through the transformer on the power supply board. Relay is not clicking, not getting the signal to turn on. I tried to trace this problem, but I do not have the service manual for this unit and did not see it anywhere on the internet. Checked your site and you do not have it, but thought maybe you can help look for the problems. Any suggestions on what to check next?
Bu iyi bir soru mu?
Puan 16
18 Yorum
Just to make sure, you did check your fuse?
tarafından
How do you check and/or replace fuse? Where is it located?
tarafından
I have the same problem.no secondary DC voltage ..fuses ok and omron relay is also ok but no dis play
please give me advice
tarafından
If We recently learned after a lot of research and trial and error that the solution was in front of me and not on Google all you have to do is enter the back up system and reboot it pressing random combinations until I found the right one unfortunately I cannot provide that combination as I do not remember it. Just try messing with the buttons and see what happens. I hope this helps and of I can I'll try and figure out the combination
tarafından
Likewise…I had no luck until I tried LeoDJ's suggestion. Unfortunately fir me it only stays on for about 3sec and then shuts off again. Any ideas what I need to do next? Thanks! Adam
tarafından
13 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
teresa, there is an error log that can be run (if you're quick) and a reset procedure.
  • error detection count - (from OFF/STANDBY state) press & hold [PRESET <–] &[ STANDBY/ON] buttons. Release when the unit powers on. each press of [ENTER] key display a protection error count. DC errors / OVERload error / TEMPerature errors
  • error reset- (from OFF/STANDBY state) press & hold the [ALC/STANDARD SURR] & [STANDBY/ON] buttons. Release when the unit powers on. The unit will display "CLEAR?" press [ENTER] to reset error and error logs. The unit will respond with "OK".
the other thing you can do, is to go to this device page, scorll down to Service Documents, and download the service manual by clicking on the blue link. you will need both parts for a complete manual. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 15
21 Yorum:
Yes, the fuse was first on my checklist. :) I will try your suggestions and let you know what I find. Thank you so much.
tarafından
Sounds good, let us know how it is going. Best of luck to you
tarafından
Was the unit fixed?
tarafından
Thank you so much... The receiver would not turn on i took it to a technician and he couldn't fix it. I did what you said and it turn on right away. works fine. I even connected a blue tooth to the unit i use the phono input to connect.
tarafından
For my VSX-827 your key combination to reset the DC Error did not work. I had to press [ADVANCED SURROUND] and [STANDBY/ON] at the same time for 3 seconds. Then it finally turned on again!
tarafından
16 tane daha yorum göster
Yorum Ekle
RE: @thasnitch
Is the unit completely off or is there just no sound? It sounds like the amp is in what is called protect mode. Look at the user manual for a description of protect mode. If one or more of the output stages has a problem, the amp will enter this safety mode to prevent damage to the speakers.
I would suggest that you open a new question rather than continue on this one for your specific problem.
Dan
Puan 0
3 Yorum:
I got a pioneer vsx 522 , it has two problems.
1, it runs only in pure direct mode .. only analogue input is working with 5 second fade in
2, so that I tryed to troubleshoot , unknowingly I plugged out the HDMI board to display board connecting strip , the system totally cut offed, i tryed all the key ways but no use, system doesn't ON
tarafından
No power change the fuse and no power,push the power butten and present Stiller no power
tarafından
I have the same pioneer and I’ve checked if it was power cable and it’s not that but it won’t turn on I’ve tried power button and on the remote and it refuses to turn on anymore what should I do
tarafından
Yorum Ekle
How to reset the component Hi-Fi stereo system to factory...
  1. Unplug the power cord from the electrical wall outlet.
  2. Plug the power cord back into the electrical wall outlet.
  3. Press the power button to turn on the stereo system.
  4. Press and hold the STOP button and folder minus button at the same time until the word RESET appears on the display panel.
Puan 0
4 Yorum:
my stereo had no power what is the problem
tarafından
ac is dead so u need to change it
tarafından
Hello my pioneer av receiver 834 purchased a month back why does it gets shut down? And it works normal again this happed to me today .can you please help me why this happens . No noise from speakers .
tarafından
You are overloading it. It being pushed harder than should be. They will $@$* off to connect the receiver when more wattage is needed
tarafından
Yorum Ekle
Yanıtını ekle
Teresa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 52
Son 30 gün: 269
Her zaman: 70,923
