Ana içeriğe geç
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Soru Tümünü görüntüle
Soru Kapandı
Has a flashing folder with question mark after being dropped.
Laptop fell about four feet while connected to a projector. Surprisingly video did not go out. Beach ball came after it tried to process a command and wouldn't force quit with alt,comm,esc. Forced quit by holding power button, and then got a white screen and finally a folder with a question mark. Tried putting in the initial install disk to use the disk utility but only the optical drive is recognized. No sign of the HD
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I suspect the hard drive is toast. It was running when it fell and the heads probably crashed into the spinning disk. Not good. On the plus side the optical drive is working and so is the computer. Time to obtain and install a replacement drive. Hope you have good backups. Ralph
MacBook Core Duo Hard Drive Replacement
http://www.ifixit.com/Mac-Parts/MacBook-...
Bu yanıt yardımcı oldu mu?
Puan 4
3 Yorum:
On a just for grins check open up the computer and see if the connection from the hard drive to the logic board is secure. You might get lucky. Ralph
tarafından
Both good suggestions +1
tarafından
Agreed +
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 2,973
