Ana içeriğe geç
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Soru Tümünü görüntüle
iPod and possible water damage, no charge or power signal?
I'm not sure if this is related to water damage or not but I have an ipod classic that won't turn on at all. Just a clear blank screen that won't power up from being on a dock or power cord. My mother in-law wore it inside her shirt and sweated with it being there so it might have absorbed the sweat? so possible water damage?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Possible, but unlikely with this model iPod. There is more physical room than with the other iDevices. Just to make sure, disassemble your iPod using this guide. Then clean all the parts in 90%+ isopropyl alcohol. Once it is cleaned, replace the battery. Make sure you also clean the dock connector on the bottom of the logic board. Look for any bend , broken or corroded pins. Watch out for the battery connector on this model, it does have a tendency of breaking off. Use a L-shaped paperclip to pull straight up on the locking tab to disconnect the battery. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Gabriel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 299
