Ana içeriğe geç
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Soru Tümünü görüntüle
The backlight has gone
The reason im writing, is that the backlight has gone. I can still see the screen if will shine a light onto it. I recently took it into the new Apple Store, they cleaned up the connectiones inside (have proof). It started to work again. They said if it stops working, it could be a faulty connector, faulty LCD, or a faulty logic board. After a few days it stopped working again.
Could you help me?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Deni, take a look at the LVDS cable. Make sure hat it is properly seated and check on "the connector" that they previously cleaned. It is possible that it is the backlight, but there is also a possibility that it is caused by your backlight fuse having failed. You may also have to check the backlight driver. If you give us the last three digits of your serial number or the number of your logic board, we might be able to assist you a bit better.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Deni sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 86
