Ana içeriğe geç
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
497 Soru Tümünü görüntüle
Soru Kapandı
cycle lights blink washer will not run
washer will not run . no codes, cycle light will blink once when start is pushed
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Unplug it for 5 minutes to allow it to reset then plug it back in and see if it gives you any codes.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
the door lock light didn't come on. when I unplugged the electric and plugged it back in the door light came on. it ran thru a couple minutes then shut off when the door light went out. can you help me? thank you.
fred
Puan 0
Yorum Ekle
when i put a load in it starts and then stops and the light start blinking and i have to move the cloths around in the drum - or take some cloths out - but that only works sometimes.
Puan 0
Yorum Ekle
Washer stopped with twelve minutes left on the timer clothes are dry enough to take out.the washer will not restart. I unpluged the machine for five minutes and when plugged back in no code appeared. When it was plugged back in a real low hum could be heard but still will not do anything
Puan 0
Yorum Ekle
After turning power on I push the start button and hear a humming noise. Please help
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 2,098
