Ana içeriğe geç
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Soru Tümünü görüntüle
Soru Kapandı
Glue on the LCD connector
Hiya guys, I need help, tried doing a replacement screen on a customers LCD/digitiser but I accidentally got glue on the LCD connector, therefore the new screen doesn't "click into place" properly, anyone give me any ideas to fix this? Kind regards Matthew
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Ooh that stinks. I would use either of these methods:
If there is a lot in there.
Hot glue becomes brittle when it gets extremely cold.
Place the iPod in the freezer and allow the glue to get very cold and brittle.
Remove it and work quickly with a small paperclip, or metal poker (careful to not damage the connectors) to break up the glue and scrape it away. Often the glue will pop off of the surface when it is so cold.
Or, if there is just a little bit in there, I would recommend using acetone.
Acetone is a well-known adhesive remover and works well for removing thin layers of hot glue.
Moisten a cotton ball with acetone or acetone nail polish remover and apply it to the glue.
Blot with a clean cloth. The acetone will break down the glue so it can be transferred to the clean cloth.
Continue applying the acetone and blotting to remove until the glue is completely gone.
I wish you good luck sir in your endevors, hopefully everything works out.
Ash
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 157
