Ana içeriğe geç
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 Soru Tümünü görüntüle
have trouble battery charge and no backlit after a replacement lcd
Hi
Post ref chris say
image added! there is a part similar to the fuses described in other posts, a brown or orange smc with an N on it. It reads 8.3v on both sides though.
have you the number of the part for this fuse
I need this because he is wrong in my macbook air emc2392
i have a trouble battery charge and no backlit after a replacement lcd
the fuse backlit is ok and the led driver no dammage
thank you
jean
Update
I join a picture for the fuse N Broken left
jean
http://img842.imageshack.us/img842/1686/...here
Bu iyi bir soru mu?
Puan 1
3 Yorum
jean, not quite sure what part you are referring to. It might help if you give us the number for your logic board i.e. 820-XXXX and post an image of the part that you are inquiring about
tarafından
The number is 820-2838 A and ssd 504LL/A
thank oldturkey03
jean
tarafından
jean, I can not access your image right now, so it'll be a few hours...;-)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
jean, I hope I have this right :-) if not mark on you image the component in question. The part with the "N" on it is reference designator F9800 and it is a 2AMP-32V fuse in a 0603 package. the only thing this fuse does is to protect the backlight circuitry, not your charging. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
jean sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 229
