iPhone5 - Black screen after swap, constant "bong" noise.
I had a damaged white iPhone5 Screen, smashed digitizer and all.
Swapped in a black screen kit ordered off of iFixIt, actually had the screen light on the first try but with odd repetitive blocks along the top. Also the front camera was not sitting right, so I pulled it off, put it back together, and now there's no screen.
Power and Mute buttons seem to be unresponsive, it only boots up when connected to the charge cable.
It does seem to reboot with the Home+Power button.
Odd thing is, when it does boot it makes a repetitive "bong" noise every two seconds, if connected to the charge cable while muted it gives a double vibe every two seconds.
I tried power cycling the battery a couple times, and that did nothing. I can't swap the old screen back in the digitizer disintegrated as I pulled it off. Any help will be appreciated!
Bu iyi bir soru mu?
Tim Sauer tarafından
