Ana içeriğe geç
7 inçlik ekrana sahip, geliştirilmiş Google markalı ikinci nesil tablet.
Cracked screen touch screen unresponsive
Google Nexus 7 2nd Gen
Screen is cracked would like to replace, also screen is unresponsive, I am wondering if replacing the screen will correct this or is there something else I may need to buy too?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 9
1 Yorum
on my nexus 7 2nd gen only half of the screen works what do i need to buy to fix it?
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
where can I get it fixed because i'm afraid I might mess up if I try fixing it by myself? (list at least 2 places please)
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
i cracked my nexus and only half the screen woks what part do i neede to fix it
tarafından
Where depends on where you live, do a search on google maps for repair places. I got mine done at a place called Device Pit Stop but I think it is local (Minneapolis area). I also went to the national chain Batteries Plus. Batteries Plus looked at their info and told me they couldn't get the part and suggested Device Pit Stop (I have used them before). I also have local computer shop (run by a great computer tech) that I have used before.
I am lucky for things like this that I am in a large city with a lot of tech. If you are in a small town, ask around. I have had much better luck with local shops rather than large corporate shops like Geek Squad (they had a huge reputation before Best Buy bought them.
tarafından
Yorum Ekle
No no no.If the digitizer is cracked,it is unresponsive for that reason.Need new screen.I would take it somewhere :)
Puan 2
Yorum Ekle
Is Asus the only place you can get a replacement screen and digitizer?
Puan 1
1 Yorum:
Basically,you need to make sure that the digitizer is clean before putting it on,also make sure that the lcd or led screen is clean.You need to get on ebay or anywhere honestly(as long as it is legit) and search the exact screen you need.Sometimes ebay sellers' screens are not very-well built.Luck.You can search "how to install screen on....."Sometimes they make it look easy,but it isn't really.Luck... :) Seriously ask anything else.I will try to help :)
tarafından
Yorum Ekle
I have recently had this problem, and i found a solution. You will want to buy a OTG cable, ($3 at walmart). Next, connect the cable to your Nexus. The last step is to also connect a mouse to the OTG cable (wireless works best). A courser should come up on the screen. The mouse enables you to access your Nexus as you would normally would.
Puan 1
Yorum Ekle
The digitizer (top layer of glass) and the display are a single item on the 2nd gen Nexus 7. If the digitizer layer is cracked, the touch screen will be partially or completely unresponsive.
Just had it replaced locally for $125.
Puan 0
Yorum Ekle
Yanıtını ekle
Lkranz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 11,120
