Ana içeriğe geç
Japonya'da 12 Aralık 2004, Kuzey Amerika'da 24 Mart 2005 ve Avrupa'da 1 Eylül 2005 tarihlerinde piyasaya sürülmüştür.
PSP backlight not working
I have a PSP 1000 and the problem is the back light. I tried replacing the whole screen but the back light is still not working. So I am 100% positive that the problem is actually the motherboard, but everything else is working fine. I have tried the fuse fix but that didn't work either. Has anybody tried grabbing the voltage from another location within the motherboard? any suggestions on where to grab voltage from?
Bu iyi bir soru mu?
Puan 1
2 Yorum
I did check the voltage where the back light goes and it gives me zero volts, and there is continuity in its proper fuse.
tarafından Paylaş
Did you test the points where the back light would get power from with a multi meter?
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check this video and here great instructions in getting your backlight back. There are multiple fuses on the board, make sure that you check the right one.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
tehsalt sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 9,878
