Ana içeriğe geç
Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20008 Soru Tümünü görüntüle
Problems cloning a hard drive with both disk utility and superduper
Hi All,
Although I have successfully done it before, this time when cloning from an internal 320GB to a firewire 500GB using disk utility, resulted in my MacBook Pro not booting. It starts to boot, and then there's a weird symbol on the grey screen like a national speed limit road sign (struckthrough O) ?!
I noticed that the partion map scheme in disk utility on the cloned disk says 'Unknown', and it's GUID on the source drive, so maybe that's part of the problem?
Anyway, I got superduper instead, and re-did the clone but the result was identical. I didn't try to wipe the destination disk before I did superduper though - should I need to?
Any ideas? Would be much appreciated! If not, I'll try a new snow leopard install and restore from time machine, but would be nice not to have to do that.
Cheers,
Phil
Bu iyi bir soru mu?
Puan 1
1 Yorum
i have a video that will solve this problem for you on youtube: Mac Secret Trick - How to Clone Mac Hardrive with Disk Utility HDD SDD MacBook Pro 2010-2018
https://youtu.be/lfJrAcnHN2g
tarafından
Yorum Ekle
7 Cevap
Filtre ölçütü:
Seçilen Çözüm
Its called a Prohibitory sign,
http://support.apple.com/kb/TS1892
if the Partition scheme is not GUID or Apple Partition Map - its a good chance that not all the files actually copied over.
I would recommend erasing the external drive, make sure its GUID, and the partition itself is OS Extended Journaled.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
En Yararlı Yanıt
It sounds like the 500GB drive is not formatted properly. In order to boot an Intel Mac, a drive needs to be partitioned GUID and formatted HFS+ journaled. Neither SuperDuper or Disk Utility is going to check the partition scheme - they will just schlep bits as long at the target drive is mounted and writable.
The symbol you are seeing is the "Prohibitory" sign, which indicates the EFI attempted to boot the selected volume, but there is a damaged or missing low-level file. See the following article for details:
Puan 7
2 Yorum:
Great Minds think alike.
tarafından
Hi All,
Well just to update you all, interestingly enough it was what you suggested. It's worth noting that even with a new Snow Leopard install and restore from TIme Machine backup to the external disk, it STILL doesn't warn that that the disk isn't partitioned properly and therefore doesn't work.
So, I just partitioned it and used disk utility, and it was all fine.
Thanks for all your comments!
Cheers,
Phil
tarafından
Yorum Ekle
What country's national speed limit sign? UK?
Puan 0
1 Yorum:
Yes, the UK and most of Europe... although the diagonal line goes the other way...
tarafından
Yorum Ekle
Can you get the cloned drive to show up on the desktop? If so, select it as your startup disk and restart... Blessing
the disk this way usually let's you boot after. Also I've had troubles
with 10.6.1 cloned images and had to stick to 10.6, so check that too.
Puan 0
Yorum Ekle
External drives almost always come with a Windows partition scheme and formatting. I always repartition them either GUID or APM (unless they need to be used with both platforms, of course.)
Puan 0
Yorum Ekle
matthewfrey, david,
thanks, I was lost and the partitioning did the magic.
Thanks
Puan 0
Yorum Ekle
Puan 0
Yorum Ekle
Yanıtını ekle
filchambers sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 5,578
