Ana içeriğe geç
The third iteration of the 10.1 inch Galaxy Tab tablet.
126 Soru Tümünü görüntüle
held power and volume button now downloading something/frozen
My son tried to turn his tablet on but held the volume key at same time as power button, a message came up saying if you proceed it will download something so my husband tried to cancel or go back but the only button that would respond to being pressed was the volume key and now the tablet is frozen on a screen with the Android pic and writing in top left corner showing product: GT-P5210, current binary: samsung official and system status: Official
under the Android pic in middle of screen it says downloading do not turn off target.... but has been stuck like this for over an hour with no change.
Samsung support was useless to talk too.
Bu iyi bir soru mu?
Puan 15
2 Yorum
My samsung tablet 10.1 on/off button is depressed and is difficult to turn on.
Where can I find a replacement part.
cfu8741@gmail.com
tarafından
even on J7 prime will work too ?? please help me..
tarafından
Yorum Ekle
12 Cevap
Filtre ölçütü:
Seçilen Çözüm
Best bet is to let the battery die completely, then charge it and turn it on normally. I just put a tab 3 into download mode myself after reading this post to see if there was an easy way out, none of the normal methods work (power + vol down/up/home). So from what i can see you just gotta drain it then charge it :) hope this helps.
Edit: Guys, this method was ONLY for this model of device where the normal reset procedure was not working. Anyone applying this method to any other device should instead use the Vol Down + Power or Vol Down + Power + Home Button method as it’s much quicker than letting the device completely discharge it’s battery.
Of course the other option is to pull the battery but a lot of people don’t want to open their device. Just clearing some things up because it seems some people can’t understand the context of this specific situation.
Bu yanıt yardımcı oldu mu?
Puan 21
32 Yorum:
Thanks Angrylemur,
You were right that is what we had to do and it works no problem now... :)
tarafından
If your Galaxy Tab S2 is locked in "Downloading...Do not remove target..." mode, you will need to pull the battery. I know you're thinking the battery is not removable on this device, and you're right.
All is not lost, however, you can simulate "battery pull". To do so, hold the [Volume Down] + [Power] buttons down for about 5 to 10 seconds. Your device should restart.
tarafından
This worked perfectly! Thank You! so much . . . To ItsEz4Me
tarafından
It worked amazingly for me. mine stayed 4 hours in that mode i was afraid to pull out the battery thinking i will crash the phone........thanks alot
tarafından
@itsez4me GT-P5210 is not a Tab S2, you are getting off topic.
tarafından
27 tane daha yorum göster
Yorum Ekle
Volumedown home power
Puan 9
1 Yorum:
what can i do after pressing lock key , volume up and down key at same time and phone become off how can i start again
tarafından
Yorum Ekle
i had a same problem so i solved it like this
press "home button+power utton+volume up+volume down button" for few seconds...
your cell will power off then start it in a normal way
you are done. :)
Puan 6
3 Yorum:
Dear sir, thanks for good information. i have had this issue and use your guide.
tarafından
tarafından
This worked on my Samsung Galaxy tab when stuck on cool down c p u ,thanks
tarafından
Yorum Ekle
Got this message and it worked. Take the battery out. Wait 30 seconds, put it back in and reboot.
Chat InformationPlease wait for a Samsung Agent to respond.
Chat InformationYou are now chatting with 'Kathy'. There will be a brief survey at the end of our chat to share feedback on my performance today.
Chat InformationYour Issue ID for this chat is LTK1125601081130X
Kathy: Hi, thank you for contacting Samsung Technical Support. How may I help you today?
Visitor: I have a samsung Galaxy 3 that is one year and 11 months old and has frozen to a screen that says "factory mode", "Product Name: SGH-7747" "custom binary download: no" more...
Kathy: I understand that your phone is stuck at " Factory mode" . Am I correct?
Visitor: it has Loyd and says "Downloading...Do not turn off target!!" It has been in this mode for 12 hours.
Visitor: loyd the green andriod guy
Kathy: Yes, I understand your concern.
Kathy: I'll try my best to fix the issue.
Visitor: thanks
Kathy: You're welcome.
Kathy: Do you have the device with you ?
Visitor: yes
Kathy: Lets perform Soft Reset on your device, it will refresh the internal circuitry of your device.
Visitor: ok
Kathy: Please follow the steps mentioned below to perform a soft reset on your Phone.
1. Turn off the handset.
2. Remove the battery and wait for 30 seconds.
3. Reinsert the battery and turn ON the device.
Kathy: Please do not press and other keys while perform "Soft reset".
Visitor: it won't turn off. should i skip to #2 and pull the battery?
Kathy: Please do.
Visitor: hold on please
Kathy: I am with you.
Kathy: Should I provide you link for removing the back cover?
Visitor: i've got it. its appearing to start back up
Kathy: Great !
Kathy: Please let me know if you are able to see the home screen.
Visitor: yes
Kathy: Great !
Kathy: It seems the issue is fixed.
Kathy: You will see sometimes the "Downloading...Do not turn off target!!" if you press any other key while powering on the phone.
Kathy: Please do not press any keys while powering On the phone.
Visitor: Oh, I must have had the side buttons pressed while I was plugging the phone in. But it was powering down because the battery was at 1%.
Kathy: Yes, while powering On you must have pressed any other key.
Visitor: it was powering itself off. I did not try to power it on. Oh well. I'm just glad its fixed. thank you
Puan 3
Yorum Ekle
you need to download it in the computer then something will pop on your tablet that it is downloading and you finish it is fix
Puan 1
1 Yorum:
How long till battery will drain it was 54% when this happened
tarafından
Yorum Ekle
how to remove battery
Puan 0
2 Yorum:
I was factory resetting n it frozen on ;now send the package u want to apply; BUT IT FROZEN ON IT..WAT 2 DO????
tarafından
Hazel: supposed you don't have a computer or laptop to download when the Android on the Tablet
tarafından
Yorum Ekle
I have a Samsung galaxy 3 and my grandson did something to it and now it's been saying downloading do not turn off target with a green man on it for a long time What do I do .
Puan 0
Yorum Ekle
Can I know what is meaning Odin mode
Puan 0
Yorum Ekle
Idk and the green man is the android robot
Puan 0
Yorum Ekle
home button
power button
one of the volume buttons
Puan 0
Yorum Ekle
Everybody seems have a complex way of solving this, but my galaxy tab 2 7.0" gets out of that screen simply by 'holding the power button for a few seconds'. It turns off and then you just turn it back on ( hopefully booting into the OS unlike mine currently is haha .. personal separate issue tho
Puan 0
Yorum Ekle
start my huawie fone with volume as power fone is connected here download app to my fone from here
Puan 0
Yorum Ekle
Yanıtını ekle
Nat Brown sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 55
Her zaman: 96,685
