Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Soru Tümünü görüntüle
Soru Kapandı
Why is my vibrator staying on after screen replacement?
I have just replaced the screen on an iPhone 4 and when I plug it in the vibrator stays on! I have replaced about 8-10 screens for friends but the only thing I have done differently this time is I damaged and had to replace the home button. Any suggestions on what I may have done wrong?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
is this a 4 for gsm or cdma?
tarafından
Hi, It's a gsm phone
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Have you tried:
Just Hold The Power/Lock Button And The Home Button At The Same Time For About 10 Seconds Until The Apple Logo Pops Up On Your iPhone's Screen
Just works as a reboot, not 100% sure it will work. If not its might be something internal that has changed.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Hi I tried that but didn't seem to help. The battery is dead flat and when I plug it in the vibrator starts operating. Almost seems I have a crossed wire or similar. Not sure how?
tarafından
Yorum Ekle
make sure the dock connector is seated properly. be sure to check to see if there is any debri or corrosion.
Also try cleaning the connectors that touch the vibrating motor. make sure the screws are fastened all the way down and there is no corrosion.
Other than those two things there really isn't much you could've done to create this error. is it up to date on software?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 79
