Ana içeriğe geç
Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
20 Soru Tümünü görüntüle
Transmission fluid—how many quarts to fill?
How many quarts of transmission oil for my 2005 Ranger 4WD?
Bu iyi bir soru mu?
Puan 3
2 Yorum
its a 1992 ford ranger 5 speed
tarafından
patsymiller0, 1992 Ford Ranger 5 speed manual transmissionApprox 2.65L/2.8quarts US of ATF Mercon V, video link below will show how it is done.
Good luck.
https://www.youtube.com/watch?v=AC8lhIcK...
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Raleigh, Ford says that the transmission holds 10 quarts on two-wheel drive models and just under 10.5 quarts for four-wheel drive models for a complete change.
Bu yanıt yardımcı oldu mu?
Puan 4
3 Yorum:
08033530020 Mr ola
tarafından
Four wheel drive
tarafından
@Olayanju Suraju what make, model, year?
tarafından
Yorum Ekle
Uses less if you don't drain the torque converter.
Puan 2
2 Yorum:
Well how manny qrts is less if u dont drain the TC??
tarafından
Generally the tc holds about 4-5 quarts
tarafından
Yorum Ekle
Bu cevap aslında başka bir soru için verilmişti.
According to the Owner's manual :
2005 Ranger Auto Transmission Fluid - use Mercon V
4x4 with 3.0 and 4.0 engines use 10.3 Qts (9.8L)
Note the 4x2 uses 9.9 Qts (9.4L) with the 2.3L engine and 10.0 qts (9.5L) with the 3.0/4.0 engine
Puan 2
1 Yorum:
2005 Ranger 4x4 with 3.0L or 4.0L engine takes 10.3 qts (9.8L)
Use Mercon V ATF
see page 233 of manual
https://www.fordservicecontent.com/Ford_...
tarafından
Yorum Ekle
Raleigh /patsymiller0, If a manual tranny, Ford Ranger 5 speed manual transmission Approx 2.65L/2.8quarts US of ATF Mercon V, video link below will show how it is done.
Good luck.
Puan 2
2 Yorum:
How many liter atf for my ford everest 2005 model automatic transmission
tarafından
How many for a 2000 4x4 ranger xlt with 3.0 engine and automatic transmission
tarafından
Yorum Ekle
Yanıtını ekle
Raleigh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 36
Her zaman: 55,831
